Small Block Ford Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2002, 04:26 PM
The Vandal's Avatar
Engine Tech Addict
Post Small Block Ford Heads
I need to know what I can do for quick port work on a set of 1968 302 heads. They have the big nipple-thing in the exhaust port. Can I get rid of it? Anything else other than a clean-up of the short side? The engine will get around 210@.050 and .475 so I don't need tons of flow but the heads are pulled so I figured I'd do a little. Thanks everybody!
The Vandal
Old 07-30-2002, 09:16 PM
4 Jaw Chuck's Avatar
Post
You can smooth the valve stem support in the exhaust port to streamline it but I would not remove it, this supports your valve and also gives more cooling area for the valve stem. Match the gaskets and open up the area adjacent to the valves in the combustion chamber to bore size (use your head gaskets and scribe), this allows more flow around the periphery of the valve head and reduces the restriction. Don't square up the wall just lay it back a little up to bore size.
Blend the area inside the port near the valve and remove any sharp casting ridges. If the valves seats need to be done then back cut the valve heads using a lathe or in a pinch chuck the valve in a drill press and back cut using a die grinder. This is best done before the seats are cut or lapped because you'll "kiss" the seat faces for sure. Use aluminum tape to protect the seats during your grinding, use at least three layers.
The short side radius should be where you spend most of your time and make sure you don't get too crazy on the first cylinder, you will have 7 more to do. Wear safety goggles under your full size face shield and use a vacuum to pick up shavings, not compressed air. Tape your sleeves and neck to keep them out of your clothes.
One last thing, forget polishing anything. Rough surfaces flow more air-that's a fact. A 60 grit cartridge roll should be the finest abrasive you use.
Good luck.
— Han Solo
Old 03-30-2003, 04:04 PM
woodz428's Avatar
Troll Hunter
Arrow
I think you're talking about the air injector lump they started casting in about that time. You can definitely renove it and increase exhaust flow considerably. As was stated though, don't grindm away the valve guide boss.
