Small block ford rear sump pan? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2011, 07:57 AM
32chevy vett's Avatar
32chevy vett
Has any one used the rear sump pan sold by speedway motors? Made for the small ford. If so will it give the clearance I need to keep my I-beam axle.This is for my 36 Ford. I still have the D.O.H.C.. But I hate the thought of cutting a set of real good fenders. To make it fit. I'am up in the air on this one. I picked up a 5.0 H.O. Mustang engine over the weekend. I know a chevy is easy. But I don't want what a million others have.
Old 11-22-2011, 04:04 PM
rear sump pan
Hi I have not used the pan you are talking about, But back in the 70s I decided to put a 351 boss in my late model dirt tracker. I had to fabricate a rear sump for it. I removed the lower half of the pan ,reversed it ,welded it back up and had to fabricate a channel in the pan for the pickup tube to go to the the pickup. I connected the pump to the pickup with flexable tubing . You just dropped the pan about4 " and disconnected the tube . It worked great . Remember you dont have pressure on the suction side of the pump.
I am installing a 351 w in a 1954 mercury I am restoring and it has a rear sump pan. Wish i could afford a 5.0 cammer. I has a great history. My son just bought a new F150 with the 5.0 cammer in it, coupled with a 6speed auto. he said it is much stronger than his 08 5.4 triton. Have a good day Nial
Old 11-22-2011, 08:22 PM
willowbilly3's Avatar
Last journal entry: Body mods
Early Broncos used a rear sump. I think some of the specialty Bronco off road suppliers have them.
Old 11-22-2011, 08:53 PM
Wiki Edits: 27
5.0 mustang ?
The 5.0 mustang double hump pan has a little more front clearance . might work if the engine can set a little higher.
Old 11-23-2011, 06:00 AM
Irelands child's Avatar
The Ford Racing pan/kit shown by Speedway is most likely exactly the same arrangement that's currently on your 5.0L. Check your clearance between the oil pump and the pan and my guess (and recollection) is that there is enough room that you can "section" it some, weld on a new bottom at that small front hump and make it work. A half inch spacer at the two motor mount bolts might give you a bit more space as well and not screw up anything else. The Moroso pan - I think I would stick with the OEM Ford and make my own mods as necessary to fit the application.
Dave W
Irelands child
Old 11-24-2011, 08:45 AM
32chevy vett
Rear sump ford
Thanks for the feed back guys. I just got back on the 36 after a year or so.
I got the 5.0 H.O. in a swap. And thought with this engine I would not have to cut the fenders. To be honest with you.I have never had the pan off this engine. But I think if I section the pan. It would work. The more I think about it.
I have so much money in the mark 8 engine. I will just cut the fenders and save the pieces.
Ford 302 rear sump oil pan Lippy Engine 1 03-07-2010 10:15 AM
Small block rear water crossover chevy7283 Engine 1 05-30-2007 08:10 PM
Small block rear seal BMM Engine 6 01-25-2007 06:23 PM
rear sump pan for bb ford? ajbcc2 Engine 8 10-20-2006 07:19 PM
Front and rear oil sump on Ford 351W RAW Engine 8 06-05-2005 03:30 AM
