Small block Ford steering conflict - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2007, 08:44 PM
Last journal entry: 34 Finally
I am in the process of building a 34 ford with a small block Ford engine. Running Heidt's IFS and block hugger type tube headers from Summit. Mocking up steering looks almost impossible! Steering shafts run right into headers. I could cut them apart and move them from the block for more clearance but I would rather get something more suitable for the application. Running out of time..much to do. moving in 4weeks! Any ideas?
Old 07-26-2007, 08:35 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
Need a little more information what type of steering what type of box?
Success is getting what you want but happyness is liking what you get.
Old 07-27-2007, 09:49 AM
Steering box is Rack and Pinion furnished by Heidt's similar to Mustang II but made by another vendor.
Old 07-27-2007, 10:09 AM
Not A T 25's Avatar
How many universals are you using in your steering shaft? without pictures or a sketch it is a little hard to advise but it is pretty common to have at least two universals in the steering shaft often with a carrier bearing on the frame to keep it all in check. But to answer your original question I have cut header pipes and had a muffler shop bend me some replacements and welded them in. It does affect your header tune but on a street rod not for race I personally don't think it makes much difference at all.
Old 07-27-2007, 03:27 PM
It looks like I can get the steering shafts clear of the headers if I use 3-joints with a heim joint to stabilize them. I was hoping to have a cleaner installation using only two joints. I may opt to do as you suggest with the headers but I think I'll proceed using the three joints. Thanks for your input
Old 07-27-2007, 03:32 PM
Not A T 25's Avatar
Good Luck hope you get it going soon see ya cruising sometime
Power steering Bracket for Small Block Hydro boost Rob Keller Suspension - Brakes - Steering 6 11-25-2009 08:30 PM
ford small block in 48 ford pu what headers hemivolvo Engine 0 07-20-2007 04:02 PM
Small block Ford or Chevy into a W111 Mercedes 1964 220 SEb cabrera Engine 8 01-06-2005 06:58 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
Swap small block chev into 53 ford Kasper Engine 11 02-07-2002 08:19 PM
