small block into 52 chev sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2005, 02:55 AM
g,day guys Ive just pulled out the original motor and box out my 52 chev sedan and have a small block chev and 350 trans to slot in. do I have to do anything to the front end. Cheer's
Old 10-02-2005, 09:20 AM
Wiki Edits: 31
The E brake is in the way, other than that, put in the SBC mounts and drop it in.
need info on small block chevys engine-rookie Engine 1 05-03-2003 09:48 PM
small block, big block crevette Hotrodders' Lounge 3 04-13-2003 09:35 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 10:55 AM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 04:16 PM
Swap small block chev into 53 ford Kasper Engine 11 02-07-2002 09:19 PM
