-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   small block oil pressure (http://www.hotrodders.com/forum/small-block-oil-pressure-221230.html)
constructionsarge 07-02-2012 01:47 PM
just put in new cam and lifters with new oil pump in my 283 i have high oil pressure of 50lbs at idle. it is a stock pump i think it is too high ?
327NUT 07-02-2012 02:39 PM
2 things.....are you sure it's a stock pump like an M-55 and what weight oil are you using....and I hope you used a good oil with an additive and proper cam break in procedure. No offense meant, just asking.
constructionsarge 07-02-2012 05:57 PM
oil pressure
30 wt. for a 100 miles with addatives
327NUT 07-04-2012 01:26 PM
Sorry, been away for a while, by the text of your story I'm assuming that this is not a new build but just a cam change etc. If it was a new build then I would ask you how tight your clearances were...but that's not the case. I did ask you about the oil pump but got no answer. Are you sure it's not a high pressure or high volume/high pressure pump.
Not likely but there could have been a mix up at the mfg. When I first fired my 331" sbc with a Melling M-55 standard pump and 30 wt. Rotella I got 80 psi with cold oil @ 2500 rp. After the cam was broken in it would come down to about 30 psi at 800 rpm. Did the pump box contain a light purple spring that you could change out for increased oil press? Who knows, maybe that spring is in the pump instead.....by the way what's your psi at 2500?
