small block oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2012, 12:47 PM
just put in new cam and lifters with new oil pump in my 283 i have high oil pressure of 50lbs at idle. it is a stock pump i think it is too high ?
Old 07-02-2012, 01:39 PM
327NUT's Avatar
2 things.....are you sure it's a stock pump like an M-55 and what weight oil are you using....and I hope you used a good oil with an additive and proper cam break in procedure. No offense meant, just asking.
Old 07-02-2012, 04:57 PM
oil pressure
30 wt. for a 100 miles with addatives
Old 07-04-2012, 12:26 PM
327NUT's Avatar
Sorry, been away for a while, by the text of your story I'm assuming that this is not a new build but just a cam change etc. If it was a new build then I would ask you how tight your clearances were...but that's not the case. I did ask you about the oil pump but got no answer. Are you sure it's not a high pressure or high volume/high pressure pump.
Not likely but there could have been a mix up at the mfg. When I first fired my 331" sbc with a Melling M-55 standard pump and 30 wt. Rotella I got 80 psi with cold oil @ 2500 rp. After the cam was broken in it would come down to about 30 psi at 800 rpm. Did the pump box contain a light purple spring that you could change out for increased oil press? Who knows, maybe that spring is in the pump instead.....by the way what's your psi at 2500?
Low to no oil pressure on a small block 350 jaeger_bombs Engine 35 01-05-2012 04:26 PM
Small block 350 No Oil Pressure usa3990 Engine 2 06-05-2010 03:27 AM
Small Block Chevy Oil Pressure knizet Engine 25 03-21-2008 04:21 PM
chevy small block possible low oil pressure? ruski Engine 24 04-24-2006 09:18 PM
Small Block Oil Pressure Ron M Engine 4 07-18-2004 09:32 AM
