Small block pushrods - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2010, 09:01 PM
Whats the difference between hydraulic roller pushrods and standard pushrods? why cant I run standard 5/16 inch standard pushrods in my 1986 with roller cam and roller lifters?
Last edited by dewane1; 06-04-2010 at 09:15 PM. Reason: forgot to say what kind of engine
Old 06-04-2010, 09:06 PM
Whats the difference between hydraulic roller pushrods and standard pushrods? why cant I run standard 5/16 inch standard pushrods in my 1986 350 chevy with roller cam and roller lifters?
Old 06-04-2010, 09:23 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hi, and welcome.
I can't answer your question with any certainty, but I suspect there is a difference in length.
I also noticed that you have 3 (related) posts within a span of 10 minutes.
There is no need to do that. You can go back and edit your original post, or even submit a new comment in the original thread.
Old 06-04-2010, 09:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
66GMC is right- the lengths are different. About 7.8" for a flat tappet, about 7.2" for the OEM roller.
Old 06-04-2010, 10:37 PM
chevy push rods
I'm running standard stock, rockers, just hydraulic roller lifters which as far as I can see are the same on the pushrod end and ebay lists 7 1/3 inch high grade pushrods, but they say not for roller cams, confusing, about 8 bucks apiece difference.
Old 06-04-2010, 11:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are MANY different length pushrods, depending on what they are supposed to fit, whether the valve train is OEM or modified, what machining ops have been done to the heads and/or block, etc.
I don't recall manufacturer's specifying the p-rod length by fractional measurement, i.e. 7-1/3", rather they would most often be listed as 7.333" length.
An OEM roller SBC from 1986-up through the Vortec L31 engine (about 2000) used 7.2" nominal length p-rods.
That said, the exact p-rod length depends on many variables, and should be checked so as to provide the correct geometry for the valve train.
If you would care to tell the forum what it is you are building and what parts you are wanting to use, maybe some useful info will be forthcoming.
Old 06-05-2010, 05:02 AM
BOBCRMAN@aol.com's Avatar
GM hydraulic roller lifters are taller than flat tappet lifters. The corresponding pushrod is shorter. NO direct swap.
Old 06-05-2010, 12:30 PM
small block pushrods
Thanks to all for your information, ou were very helpful.
'57 Chevy Small block swap Unkie Hotrodding Basics 5 10-10-2008 11:48 PM
how strong is a 350 small block ChevyVan Engine 18 01-04-2007 11:27 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
400 small block idling problems 19nova72 Engine 15 04-16-2006 02:53 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
