small block stumbles
I have a 400 small block chevy, bored 40 over, a 458 lift cam, edlebrock airgap rpm manifold with a 1407 edlebrock manual choke carb. Ever since I put this all together,(over a year) the engine stumbles to the point of dying if I floor it and don't let off.this will happen off idle. It also stumbles when the vehicle's moving, but recovers before it dies.
I thought I had trash in the carb from some gas I got once that had trash in it enough to dirty 2 fuel filters. I've completely torn down the carb and cleaned it, and even though it didn't look like it needed it I put a new acelerator pump in it. I've moved the rod to the pumps arm up and down in the three holes for adjusting pump stroke. I've also had the timing everywhere you could imagine by advancing the distributer to the point of it making the starter drag to the other end until it backfires back through the carb. I've changed the springs on the curve kit, and adjusted the vacuum advance to so many combos I couldn't even try to list them.
Can someone please give me some suggestions about what might be causing this. something aside from the typical holly fan telling me to get one of them.
Any insight on this will be greatly welcomed, I'm running of of ideas.
