Small block tunnel ram. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-28-2012, 08:37 PM
Originally Posted by lg1969
  #17 (permalink)
Old 04-28-2012, 09:04 PM
Banned
Couldn't have found a worse article on tunnel ram carbs if I tried.
  #18 (permalink)
Old 04-28-2012, 09:51 PM
X2! Lots of this stuff is written by guys who never tried the setup, they just read the naysayers stuff, and it is based on some logic, and decided no one should do it. They're all looking for the "perfect"tune and the tunnel ram set up won't give you that without lots of work, but it will give you lots of fun and reasonable performance if you do it right. Mine works with an automatic and 2800 rpm stall and it will idle in gear with a solid roller in the 240 at .050 neighborhood. Gas mileage might be the best but it starts, runs and looks and sounds GOOD! AND... I'll leave the stoplight with anyone that wants to and be OK, even though it's only a 308 cid SB Ford.
  #19 (permalink)
Old 04-28-2012, 10:29 PM
lg1969's Avatar
Google "Tunnel Ram 406"
There are more article on this subject. And they all the same. Overcarburetion is the one mistake in tunnel ram setup. If one 600 was made work, What make you think two 600 CFM is going to perform better. BS! Just because you see them at the track does not mean it's works on the street. Half of you guys do not even own a cars with tunnel ram. What make you think you are experts on tunnel ram.
  #20 (permalink)
Old 04-28-2012, 10:43 PM
im sure two 600 will work, but tell me how 1200cfm is better for steet use on a slight over stock engine vs using 780cfm? To each his own..
  #21 (permalink)
Old 04-29-2012, 09:55 AM
Banned
You can't size a carb on a single plane like a carb on a tunnel ram. Its a lot closer to an ir setup where 1200cfm total is about half of what you need. 600's will be fine. A mechanical carb with dual accelerator pumps would be better but the vac secondary can be adequate.
As for being a lot of articles on the subject the internet probably has more false information than true, as a result of anyone being able to publish.
  #22 (permalink)
Old 04-29-2012, 01:50 PM
lg1969's Avatar
If this is your theory. It's a poor one. I've been running my setup for 35 years and yes I made mistakes in the past. Installing big carbs to make it run faster and all it did is bog when I floored the gas pedal. And it ran OK if you stay off the secondary. It would bog or lean backfire off line once in a while, or run sluggish. It made a world of a difference when I installed a pair of 390 CFM.
  #23 (permalink)
Old 04-29-2012, 02:39 PM
Read Dave Emanuel's book about tuning holley carb's , he backs up lg'69's statement about running small carb's !! I'd consider him pretty much an authority.....
dave
  #24 (permalink)
Old 05-01-2012, 12:11 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Wow I always see this when tunnel rams are even mentioned, you have the poser ( the guy who wants the looks and sound but doesn't care about real power or true potential) arguing with the guy who builds for the true performance of a tunnel ram on the street or track! I don't understand why your arguing!!! You would think if your putting the money into tunnel ramming an engine You would tune it to its potential and still be street-able!! Its like the guy running a dummy blower for looks arguing with a guy running 35# of boost! I mean G, you guys could get better performance from a dual plane single carb, Why are you running tunnel rams ??? All the guy asked was if he could run the carbs he has and he can!!!!
No offense meant (to each his own), But you should ask the thread starter: do you want to pretend or do you want to walk the walk & talk the talk !!!
Jester
  #25 (permalink)
Old 05-01-2012, 04:13 PM
lg1969's Avatar
Jester
Why people like to be different? Because it's there. I have seen fuel injectors with stacks coming threw the hood, and when you take a close look, he's running a 4 barrel. He did it for looks. You see a single Quad setup with dual plane, you see them all yon. There all the same. Tunnel ram is not just for looks. This is no lie, I raced a 69 Chevelle 396/375 with 4 speed and 4:10 gears and I beat him. And that's with a 355sbc on a tunnel ram with a pair of 390 carbs, 3 speed automatic and 410 gears, .
  #26 (permalink)
Old 05-02-2012, 02:33 PM
The cfm formula does not work for ram intakes single quad rams or tunnel rams its designed to figure the cfm for an engines basic capacity to move air in and out with vacuum alone. When running a ram (Ram air because its ramming air into your cylinders) the ram effect at rpm (increased air velocity) in the runners creates pressure at the intake valve and when the valve opens the pressure pushes the fuel air charge into the cylinders thus increasing the volume of air in that cylinder beyond its basic capacity! The longer and straighter the runner the higher the velocity and the more air is forced into the cylinder beyond the engines ability to to bring in the air fuel charge with vacuum alone. So the tunnel rammed engine at 6000 rpm can flow 1400 or more cfm! a good 750 more cfm then a lowrize single 4 barrel intake on a 350 chevy built equally in the same car. Then when you utilize small carbs you are actually cutting down the fuel air volume and ram effect of the intake (killing the hp and torque potential). Add velocity stacks or a scoop and cfm increases even more on the same 350 engine! The cfm formula does not work in a tunnel ram scenario!
I read the article that was posted earlier from national t bucket alliance and I think its gibberish when applied to tunnel rams!!! I also have set up tunnels for customers with small carbs and if tuned right will work on the street but Ive also set up 8 cylinder engines to run on 6 cylinders (Cadillac for example) during the gas crunch in the 70's at the dealers! And to me it amounts to the same thing it works but your hp and torque are gone!!!! Why buy the Cady? Why buy the tunnel! Unless you dont care about the benefits? Its just never made sense to me!
Firebird or other members can probably elaborate on this and explain it better then I did!! this is all from memory when I was in engineering classes in the 60's so I might have left a few things out!
Whether your running for power or running for looks have fun and be careful on the street or track
Chris
  #27 (permalink)
Old 05-02-2012, 03:07 PM
Thanks Chris! Not sure I completely understand it but sounds good... .
Just to clarify to everyone. This intake and carb setup was given to me... I have no money in it. I also have no money in the motor other than the cost of the actual car. The idea is to install it and have fun while I am collecting parts for my BB build. Building the BB now or anytime soon is not feasible based on all the other work that needs to be done. I am wanting to do this for fun not all out performance. It is not intended to be all out performance but more of as much performance as I can get realizing the limitations.
For all the "Why do it's" my answer is "why not?" But thanks all for the input. I have learned a great deal and may transfer this to the BB build which I know will handle it.
Wade
  #28 (permalink)
Old 05-02-2012, 03:47 PM
lg1969's Avatar
The Raming effect is only 2% to 5% increase. not 50% increase. Where a typical 350 flow 608 cfm to 1200cfm is pure bunck. If you have an article that will back you proof, Show it.
  #29 (permalink)
Old 05-02-2012, 08:06 PM
The ram effect increases with variables, scavenging of cylinders, size of valves, porting, anti reversion , design of plenum and runners, cam overlap, temperature, rpm, we used to pack our intakes with dry ice before a pass, used cool cans, By your explanation a 350 running a single 500 cfm carb by formulated max cfm at specific rpm say 5000 when going to dual 4 barrels you would run 2 250 4 barrels. ( just an example)
The 2 to 5% increase in ram effect does not directly correlate to cfm in a 2 to 5% increase. The vaporization of fuel in the air charge is a big factor the better the vaporization the better the cylinder efficiency the more cfm your cylinders can use and still burn efficiently as rpm increases! your limiting the flow and efficiency of the tunnel ram with small carbs. I dont see your argument in this.
We could pick articles all week off the internet I could post the "anvil articles" and you could post the "t bucket alliance" article or any others on the internet it would never end! Im not attacking you for your views. Im stating my views so take them or leave them!
Maybe Smokie or Grumpy could have used your advice and their cars performance would have been enhanced by your opinion on ram induction and cfm. Your running 2 390 carbs and your happy as honey on a roll, my wifes running 2 600's on a 302 and im running 2 750's on a 302, shes tickled and I want to go bigger with more rpm. I wouldn't be happy with 390's. It would bother me so much I wouldn't sleep at night!!! But there are degrees in performance wanted by hotrodders from the guy thats satisfied with: "it will leave the stop light with any other car and keep up", and a guy like me who stays awake at night wondering how to squeeze a little more out of my set up!!
Jester
  #30 (permalink)
Old 05-04-2012, 04:43 PM
F-bird: your answer should be included with every tunnel ram sold, its technical and very understandable I cant remember everything like I used to and you filled in pretty much all the blanks!
Its funny as I age I forget the technical of why I do things! Ive been doing them for so long its just a natural thing to do! I tried to explain to a customer one time why I was stagger jetting his carbs with a larger jet on one side of his front metering block (Because he was told by another shop that no one does that) and I could explain because he had a right front cylinder running a little lean but it took forever and I still dont think he understood why with a plenum I had to do that ! That cfm formula is all over the internet and people keep referring to it in threads and articles and use it as the gospel on a lot of the forums to choose carburetors no matter how the engine is built! Like the progressive linkage on the t bucket article posted earlier and applying it to a tunnel ram? How many people read that and are running that set up Ive never seen progressive linkage on a tunnel ram. Or is that excepted practice in some circles ?
Any way thanks for explaining to gamecock 66 what I may have confused him with a lot better then I could have
Chris
To tunnel ram or not to tunnel ram maverickmechanic13 Engine 107 03-04-2012 08:33 PM
Tunnel on small block rbengines Engine 16 06-18-2009 08:19 PM
sbf hi ram tunnel ram 72fordlb Engine 9 04-13-2009 05:15 PM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 02:22 PM
Tunnel Ram 69 chevelle SS Engine 2 08-07-2003 10:06 PM
