Small Block Vs. Big Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 09:36 PM
FourSpeed460's Avatar
Ford 460 The only way to go!
I am wanting to hop up a Ford Ranger. Ive got a 351 or a 460 to choose from. What do you guys think? Why?
Old 01-22-2006, 10:12 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
A 351 ... what (W, C, or M.)?
I'm a big Cleveland fan but I'm thinking that the W might be easier. I'm sure there are a ton of 302/5.0 powered Rangers around, so lots of stuff made for that conversion would probably work on the W as well.
The "C" block mounts pretty much the same as 302, except that I believe that it sits back further ... it did in my 68 Torino anyway. The heads are also pretty massive, and might be pretty tight in that engine compartment. The Torino had shock towers on it and they were REALLY close to the headers.
They make a lot of stuff for the W now ... including hi-flow heads ... so you can get a lot of ponies out of them.
A 460 would be great if you could "shoehorn" it in there ... those trucks had steel or plastic inner fenders, didn't they? Maybe with little mutilating and fenderwall headers???
Heck ... I've seen a BBC in a Monza.
Old 01-22-2006, 10:13 PM
johnsongrass1's Avatar
Race it, Don't rice it!
SB is probably easier to fit from sheer size. You have a heck of a time gettin the thing to handle well with the BB weight.
Old 01-22-2006, 10:24 PM
BOBCRMAN@aol.com's Avatar
Johnsongrass! is correct on that. Even with just the 302 in it. My Ranger shorty was front heavy feeling. The 351 will go as fast as you want and almost hold the road. MOST Big block anythings, plow/understeer during corners and handle badly. Been there with several other projects..
Old 01-22-2006, 10:29 PM
Too Damn Slow
I'm partial to big blocks in mini trucks.
www.cardomain.com/id/slowride454
Big Block Or Small Block?? pi71 Engine 15 04-30-2005 12:57 AM
Big Block or Small Block? help please CUL8R Hotrodding Basics 12 04-05-2005 07:51 PM
small block, big block crevette Hotrodders' Lounge 3 04-13-2003 09:35 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 10:55 AM
well a ford big block bolt to small trany foxstd05 Engine 0 11-25-2002 06:33 PM
