Small block without acc holes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2010, 06:36 PM
chlsnk's Avatar
"Love what you do for a living
I now have the 461 double hump heads bolted up to the long block now the trouble is how will I mount my alternator and powersteering pump. The plan was to find a old alternator or generator bracket for an engine with no acc holes. And as far as powersteering I've been told the best way to go is to make a L shaped bracket that bolts up to the first header bolt and wraps around to the powersteering pump.
Has anyone used this fix? Or any others and could you post pictures or sketches if you have them. Thanks!
Old 05-20-2010, 09:37 PM
Alt. and P.S. brackets
I've just finished a 1992 S10 with a 355 SBC with 461 heads. I used the original Alt. brackets and fabricated one from the lower W.P. bolt to the back of the alt. where the bottom bolt goes. I used an old style P.S. pump that bolts to the W.P. And an L shaped bracket like you mentioned to the first header bolt. So far no problems. I'll try to get some pics for you.
ID:	45813   Click image for larger version
ID:	45814   Click image for larger version
ID:	45815   Click image for larger version
ID:	45816   Click image for larger version
Old 05-27-2010, 09:25 AM
chlsnk's Avatar
Thanks for the pictures slick setup!
Old 05-31-2010, 05:41 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
You can also look up Bills Brackets he has them for a SBC but must use a short water pump
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 07:26 AM
how strong is a 350 small block ChevyVan Engine 18 01-04-2007 11:27 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
400 small block idling problems 19nova72 Engine 15 04-16-2006 02:53 PM
big block or small block ford? stangfiend Engine 3 12-10-2002 09:55 AM
