small cam's for chevy small block's - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2003, 03:25 PM
I have a corvette cam It's about 430 to 434 lift. If i put I my 355 with worked 441 heads edelbrock perfomer intake edelbrock 600 carb. would it run and sound ok. 700R4 with 3.73 I doing some work on my motor . Would it have a slight lope idle.
Old 06-12-2003, 03:42 PM
That's a pretty mild cam but it'll work.
Old 06-12-2003, 08:51 PM
GearHead69's Avatar
'70 Chevelle '70 C10
Your idle will be stock and smooth, I have a 475-498 in my truck with a 327 and I can bairly tell it's got a "cam" the idle has a very slight choppy sound and it immediatly goes away when you tap the gas. With the 430-434 the lobe seperations might be different and make your idle more rough, but if you want a lopy idle you need a 500+ lift cam but not to big. I'm building a 350 small block and putting a 580 lift and I hope it will be setting car alarms off!!!
Old 06-13-2003, 10:31 AM
USA1's Avatar
Valve lift really has very little to do with how "lopey" a cam sounds. Duration and overlap and lobe separation are more what determines the idle quality. Some super stock cams have over 300 degrees of duration with the stock lift numbers.
Old 06-13-2003, 10:59 AM
GearHead69's Avatar
The duration @50 on my 475-498 is like 230-240 and 114deg lobe seperation, it's pretty mild. I figured with different lobes and stuff it could determin the idle.
Old 06-13-2003, 02:55 PM
E.T. divided by $ spent= Speed
The tighter the Lobe sep.the more lopey,depending on duration.
70 nova,with your setup you didn't list compression ratio.But heres what I would do If ya got at least 8.5:1 compression go Comp EX262 dur.218/224@050 462/469lift 110/lsa.should be fine with a stock stall converter too.
Your vette cam sounds like the L69 cam.It'll be a smooth idle.The car will run OK but could run better with a more precisely matched cam.
Old 06-13-2003, 08:53 PM
cam
What would the duration on a L69 vette cam be
Old 06-13-2003, 11:11 PM
I think 198/202@050.L69 was the 305HO.But I believe they used that same cam in 350s too.
Old 06-14-2003, 11:02 AM
Thank's for ever one's help.
