Small carb issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2010, 10:39 AM
Small carb issues
Hello. I am putting together a Chevy 383 and would like to know what I would expect if I put my 500 cfm Carb on it. Will it just limit my power? Will it do some damage? Just curious since I already have the Carb and have not settled on a new one yet.
Old 04-05-2010, 10:46 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Properly calibrated (tuned), it will not damage your engine. It will limit the max output.
Old 04-05-2010, 01:30 PM
302 Z28's Avatar
Ditto, but mated to the proper other components can be made to rune very good. I have seen plenty of 2 barrel SBC's running 12 second quarter miles.
Vince
Old 04-06-2010, 07:59 AM
Thanks for the response. I'll use the 500 cfm in the beginning and decide if I'm happy with it. I'll keep an eye out for a 600-650 in the meantime.
Old 04-06-2010, 03:16 PM
If you find out that your 500 does not work well if you go to ebay you can get a refurbished 600cfm holley carb from holley them selves for about 50 bucks less then a brand new one and they are basically brand new carb not worn out ones that was rebuild. I put one on my 350 and I had to go up 5 jet sizes on the front to get it where I need it but it runs really well. It also depends on what cam you got too.
Is your motor basically a stock type motor or is it built with high flowing heads big cam etc. That also plays into if the carb can work for your engine. Fuel curve has a lot to do with things too and if you got a big cam to small of a carb will never idle right without doing a lot of things. Hope it works out for you.
Eric
Old 04-06-2010, 09:17 PM
The 383 will have Performer heads, 9:1 pistons, Vortec heads with new springs to accommodate a Comp Cam with .495int/.502exh lift and 110 lobe sep. I would think the 500 cfms will be sufficient for street cruising.
Old 04-06-2010, 09:46 PM
After going to the trouble of building a performance engine, why choke it down?
I would think that 600cfm would be a minium for a 383 with upgrades.
I run a Q-Jet on my stroker. TF heads, Edelbrock RPM intake, true duals, CC XE274H cam.
Old 04-11-2010, 12:49 AM
cfm = (RPM X VE X CID)/3456 = (5000 X 0.95 X 383)/3456 = 526.20 cfm
Your 500 cfm carb will do just fine for cruising. Anything more and you will need the 600 cfm carb:
cfm = (RPM X VE X CID)/3456 = (6000 X 0.95 X 383)/3456 = 631.68 cfm
Old 04-11-2010, 09:11 PM
techinspector1's Avatar
Wiki Edits: 326
You can cruise it with a 1-bbl, but if you want power, it needs at least a 750.
Carb Recommendation please My68Vette Engine 29 07-03-2009 05:14 PM
Carb selection help SLR_65 Engine 2 09-03-2007 05:44 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
idle o n a 400 small block with edelbrock carb bigcam Introduce Yourself 2 05-08-2006 09:17 PM
priming a new edelbrock carb crshrmn3 Engine 8 10-29-2002 05:04 PM
