small chevy problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2011, 10:06 PM
small chevy problem
just wanting to find out what small block chevy i have. been told alot of wrong stuff mabey yall can help.her goes my block# 3932386 head#3927185 i.d.#180140555 also found these#'s k12 021 & 51996c on front of block with i.d. can anyone help? thanks
Old 12-15-2011, 11:28 PM
SSedan64's Avatar
3932386** 302-327-350ci **68-74** 250-350HP** 2 & 4-Bolt
3927185** 307/327/350ci** 68-79** 1.72"/1.50"** 70cc
Look on the Front right of Block, just in front of Head for a Suffix code.
Old 12-16-2011, 12:38 AM
interesting block #
Hey misinformed,
According to my book Chevy by the numbers, both your block and heads are 1969 and in most cases its a 4 bolt 350. However this number was used on the 69 camaro block in the 350 302 and 327 version. When i looked up the heads they were rated at 235hp on the 327 Impala, 200hp 307 chevelle and Chevy ll, but in the camaro 200hp 307 and a 210hp 327. So if you have a 2 bolt its a 210hp 327. That 180140555 # I think is a warranty replacement block. Hope that helps.
Old 12-17-2011, 06:25 PM
thanks yall that helped alot.
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 12 07-19-2007 08:07 PM
Chevy Small Block Seal and Pan Problem?? 89SDime Engine 1 07-12-2006 09:32 PM
small block chevy water pump problem engineman Engine 8 06-15-2006 08:23 AM
small block chevy cold start problem bennett Engine 7 04-09-2006 11:44 PM
small cam's for chevy small block's 70 nova Engine 8 06-14-2003 11:02 AM
