Small clunking noise from rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2010, 08:18 AM
I have a 03 Dodge Ram 1500 Quad Cab and just outta no where it started making a lil clunkin sound like its comin from the rear end or the tires! It mostly does it when i have my foot on the gas. Any ideas? Thanxxxxx!!
Old 03-22-2010, 09:13 AM
Frisco's Avatar
Glad To Be Here
If you notice it when first starting out from a stop (either forward or reverse), the first thing I would check is the u-joints on both ends of the driveshaft. Next would be for a loose rear wheel(s). Remote possibility would be loose or broken shock(s) or rear spring(s).
If it seems to be a more constant repetitive clunking sound, check for something attached to or stuck in one of the tire(s).
I don't mention the rear end gears or wheel/axle bearings because that would usually result in a whine or growling sound rather than a clunking sound.
Could also be worn ball joints or steering components in the front end. That would be more of a popping sound.
« 700r4 | gm 12 bolt »
Noise problem with a '02 4L60E w/video clip Jason Transmission - Rearend 6 03-22-2009 06:55 PM
327 large and small journal motors 31 Ford Coupe Engine 9 09-08-2008 12:09 PM
400 Small block making banging noise when trying to start Aboveknee Engine 9 09-05-2008 07:35 PM
Rearend Noise !! Grogetter Transmission - Rearend 1 11-22-2006 09:54 PM
