try this http://www.davessmallbodyheis.com/
Get the Blaster II coil.
Cole |
If you are wanting to replace the distributor, get one made for a blower application, Crane, Msd, sometimes referred to as small cap distributors.
A good "points size" housing modern electronic distributor with vacuum advance should drop right in for you and clear just fine, they just require a seperate coil. The 8360 is the same size as a points housing is |
thanks ericnova I did not know that the blower stuff is smaller, always learning. I think I am going to go with the MSD Ready to run Pro-Billet number 8360. It is the same size as a point distributor and needs nothing but a coil. So I will go with the Blaster II as recommend. Thanks Guys
| does the small block chevy have a "proper" name? | Hoxviii | Hotrodders' Lounge | 62 | 11-21-2009 07:50 PM |
| HEI Big Cap to Small Cap | ericbr | Electrical | 1 | 12-18-2006 05:04 PM |
| Converting small chevy distributor to HEI | bbcwgn | Engine | 2 | 11-28-2006 03:46 PM |
| Small Base Circle Cams | Warrant | Engine | 4 | 10-13-2006 07:31 AM |
| need info on small block chevys | engine-rookie | Engine | 1 | 05-03-2003 08:48 PM |
