We used to see this problem with epoxy primers as the take so long to fully cure, example Ppg's dplf with 401, it will flash and you can paint over it but it is still drying underneath, Then you put a clear over it and the shrinking begins, Change to a 2k sealer like Ppg Dps series or compairable and you will see this problem go away, I thought the same thing years ago as I was a believer in epoxy, use it as a primer not a sealer and your problems will be few.
