Small frame (case) GM alternator donor cars - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 10:49 PM
ken47's Avatar
Many hot rod parts suppliers advertise "small case" alternators (in the 100 amp range). What donor cars (single groove pulley) would these typically come from? I am using it in a T bucket with an SBC, low mount, drivers side installation. The 10 SI (6 inch or 150 mm case) alternator I have does not allow for fan belt adjustment before the alternator case hits the frame of the car. So far in my research it looks like they might be the GM CS130 (130 mm or 5.12" case) model but I am not certain about this. Half an inch more space between the alternator and the frame would solve my problem.
Thanks
Old 05-01-2006, 06:38 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Try a shorter fan belt.
vicrod
Old 05-01-2006, 08:34 PM
302 Z28's Avatar
vicrod
Or solid mount the alternator to where it is non adjustable then install an adjustable idler pulley.
Vince
Old 05-01-2006, 10:01 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Or a larger Diameter Aftermarket Alternator pulley.
Tons of options..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Building my own frame Nightfire General Rodding Tech 24 07-19-2005 06:47 AM
Frame Welding 57chevman Suspension - Brakes - Steering 12 11-15-2004 10:52 AM
Best book for GM small blocks Jag Daddy Engine 2 06-15-2003 07:45 AM
