Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small gap between hood scoop and hood
Old 04-07-2013, 08:01 PM
Lizer Lizer is offline
On my 67 Mustang's hood I bolted on a fiberglass hood scoop for a 69 Mach/68 428CJ. Between the scoop and hood there is a small uneven gap from the fiberglass not being perfectly straight. I can't even capture the gap well in a picture. The largest gap opening is probably larger than a 1/16" but less than 1/8". I could live with the gap, but it'd be a lot cleaner if I could eliminate it.
I use PlioGrip 2k seam sealer, I think #6. Is there any reason I couldn't just seal that gap up with this?
