Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small gap between hood scoop and hood
Old 04-09-2013, 07:32 PM
sedanbob's Avatar
sedanbob sedanbob is offline
It seems like you could use something like a business card like a feeler gauge to identify where you need to remove material from the bottom of the scoop - if the card can't slide in, mark that spot for shaving. Use a long sanding board to keep it even. Measure, take a little off, measure again, and repeat until you get a snug fit. You will be removing less than 1/8".
The Following User Says Thank You to sedanbob For This Useful Post:
Lizer (04-09-2013)
