Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small gap between hood scoop and hood
Old 04-13-2013, 06:44 PM
Lizer Lizer is offline
I shaved it tonight and now it's much better. There are two spots....the very front points on the sides and the very rear corner...where the fiberglass is just too high and if I were to sand it so it's even I'd be sanding off a lot...prob more than 1/8". I bet I could slide a paint stick under these two areas.
How I could I build these parts of the scoop 'down?' I have polyester resin that you'd use with glass cloth. I'm trying to figure out how I could goo that on these areas, maybe gooing more on after it sets to build where I need it, then sanding to form.
