Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small paint bubbles/blisters
Old 11-29-2012, 04:12 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
It may not be rust, but left alone it probably will be...bubbles or blisters in paint are usually caused by moisture...this moisture very often comes out of your compressor into your air line and out your gun...You may not see it when you paint and it can take years for it to show up as a blister or bubble. The only solution is, as you said to sand it down, polishing is not and option, it needs to be removed, repaired, and painted.
Sorry about that but that's what it looks like and usually it is.
Ray
