Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small paint bubbles/blisters
Old 11-29-2012, 04:21 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
As far as repairs go, you can remove the blister by block sanding, priming the area with appropriate primers, block sand, blend the base coat and re-clear the panel...you could spot paint it and polish, but that brings other issues to the table...This method is probably the safest with the best results. When re-doing the panel, make sure your compressor isn't spitting out moisture but using filters and moisture traps for insurance.
Ray
