Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Small paint bubbles/blisters
Old 12-17-2012, 09:25 PM
35prog's Avatar
35prog 35prog is offline
Last journal entry: More photos
Hello, Appears the majority feel it is moisture related, I believe it may be just a "gassing out" issue. If there is any filler in that area it may be that a pinhole in the filler was bridged and an air pocket was the result. Did you use etch primer or epoxy on the bare steel?
