It may not be rust, but left alone it probably will be...bubbles or blisters in paint are usually caused by moisture...this moisture very often comes out of your compressor into your air line and out your gun...You may not see it when you paint and it can take years for it to show up as a blister or bubble. The only solution is, as you said to sand it down, polishing is not and option, it needs to be removed, repaired, and painted.
Sorry about that but that's what it looks like and usually it is. Ray |
As far as repairs go, you can remove the blister by block sanding, priming the area with appropriate primers, block sand, blend the base coat and re-clear the panel...you could spot paint it and polish, but that brings other issues to the table...This method is probably the safest with the best results. When re-doing the panel, make sure your compressor isn't spitting out moisture but using filters and moisture traps for insurance.
Ray |
As for rust, metal is very porous, and sometimes rust can be deep in the metal, you grind and clean off the surface. It looks good and clean but underneath that rust is there and it will travel up to the surface once again. I know cos I went through this when I restored my 66 Pontiac Bonneville. 2 years later the rust returned and I was so sure I got it all. So I have been exactly where you are. Gorgeous paint on my car and as it was a candy, there was really no way to spot repair it. If you want to know exactly what's going on, you're going to have to dig into one of the bubbles. You can try sanding it down. Use a hard block like one of Motor Guards Run Blockers. I use these all the time in cases where I have to sand something out and not get to too far into the surrounding clear. Maybe you'll be lucky and they sand out. Good Luck. Hope its not rust but I think it just might be. |
Usually in cases like this, moisture is the culprit that caused the metal to oxidize under the paint...when metal oxidizes it gives off gasses, these gasses cause expansion and they result in bubbles in your paint. JoAnn, good to hear from you again, I think it's been awhile since I saw you last post. Ray |
Here's a very important tip to anyone doing painting in their shop............
Please take the time to drain your compressor. It should be drained at least once a month. If not to remove moisture from your airlines, but keep the inside of the tank from corroding as well. Having a good filter right inline is always a good thing. |
Thanks. |
Hello, Appears the majority feel it is moisture related, I believe it may be just a "gassing out" issue. If there is any filler in that area it may be that a pinhole in the filler was bridged and an air pocket was the result. Did you use etch primer or epoxy on the bare steel?
That's a terrible feeling when something like this happens
; I've been there! Like the other replies if your going to get help you need to tell what products & what procedure you used. From experience and advise from PPG that we received - you need to 'seal' before laying down the the color. This could be what happened if didn't you seal the primer surfacer before painting. It could be that the color was so hot (chemically) that it burned right into your surfacers and body filler and then trapped moisture under the surface. If you haven't solved the problem yet, as I see it the only way is to find out. Would be to first lay down a strip of masking tape on all four side of the bubble and shave it off with a razor blade. Then let the viewers know 1)what you see, 2) what products you use maybe then someone can give you hand in where to go next. Just so you know I am not current on todays 2 stage products, only experience is with one stage and sealing with with DP-40 before paint.
[QUOTE=ReflectImage;1630742]That's a terrible feeling when something like this happens
; I've been there! Like the other replies if your going to get help you need to tell what products & what procedure you used. From experience and advise from PPG that we received - you need to 'seal' before laying down the the color. This could be what happened if didn't you seal the primer surfacer before painting. It could be that the color was so hot (chemically) that it burned right into your surfacers and body filler and then trapped moisture under the surface. If you haven't solved the problem yet, as I see it the only way is to find out. Would be to first lay down a strip of masking tape on all four side of the bubble and shave it off with a razor blade. Then let the viewers know 1)what you see, 2) what products you use maybe then someone can give you hand in where to go next. Just so you know I am not current on todays 2 stage products, only experience is with one stage and sealing with with DP-40 before paint.[/QUOTI wasn't going to reply but after thinking it over I decided I better and the only reason is that if someone else reads this they are not getting the right information. ReflectImage....I don't mean to offend you but in this case you are wrong...If this is the information that a PPG rep gave you...The PPG rep was wrong. Sealer has absolutely nothing to do with what happened here, sealer is a product designed to even out poor substrates, for example, if you have a vehicle with several different substrates, say lacquer primer and or whatever Acrylic Enamel, or a vehicle that is not sanded with the fine grit required so sand scratches won't show when painted. If a vehicle is prepped properly and the substrate (either existing paint or a quality primer) is consistent, sealer is not required and has no bearing on what happened here. The problem is either trapped moisture under the paint causing rust or existing rust that was not removed completely before painting. So again ReflectImage, I'm not trying to offend, I'm just trying to correct...And yes, I was a Rep for PPG. Ray |
It could even be a lacquer primer if that was used... we need to know if it was stripped to the metal and what was done after that metal preps ,primers did you wax & grease it...theres a ton of stuff but moisture\oil in the air line and lacquer primers or improper metal prep are the most common.but explain the proceedure and materials used from start to finish. but be prepared ,when you see bubbles even small ones theres only two ways to deal with it ,,,,live with it or sand down untill the bubbles are gone,most times it has to go all the way to the metal before they're gone..but you might get lucky and only the paint has to come off...never know but you cant just buff them out ,you need to fix the problem or just deal with it..
.It looks pretty good from here though |
Doesn't look like he even returned to the post? He could shave the surface off and see what is under there, a careful shave cut and one of those fake bullet hole stickers and he would be set My hunch is acid wash primer or similar as the original cause. But I am not a gambling man, so I wouldn't put any money on my hunch,LOL. |
Ray |
Hello 69 Widetrack. No worry, I am too old to be offended and I am always ready to learn. Anyway you are most lightly right about this particular situation of small paint bubbles/blisters. With my situation, the deck lid brook out in little raised bubbles after sitting in the sun for a few hours. The Deck lid was chemically stripped down & dried before applying DP40 metal sealer, followed with body fillers and primers. I am sure we were using Ditzlers Polyurethane Black Paint, being black may have something to do with it. The mistake we made according to the rep (I want make a correction it was a Ditzler rep) he said we were supposed seal with DP40 before laying down the paint, to keep the paint from burning into the substrates. We took the deck lid down to metal & redid the body work, got it all in the same substrate and followed the rep suggestions, spayed on a light reduced coat of DP40, scuffed lightly with scotchbrite before laying down the paint. Wrong or right - it turned out great. To make a long story short - we continued to do other cars with the same process. This was a long time ago - have been retired for over ten years - I guess things have changed. Anyway, what happened to this thread starter?
| I'm getting small bubbles/specs when I spray Clear Coat | jfaur | Body - Exterior | 20 | 04-09-2013 08:30 PM |
| Paint Blisters | KENMO | Body - Exterior | 11 | 08-31-2010 11:09 AM |
| Bubbles in paint | TrannyGearhead | Body - Exterior | 1 | 01-10-2006 07:56 AM |
| Tiny bubbles in paint!!! | AlanTA | Body - Exterior | 6 | 09-08-2004 07:31 AM |
| small bubbles under window rubbers | steveo30 | Body - Exterior | 0 | 07-15-2003 03:31 PM |
