Small port big block chevy heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2005, 09:15 PM
i have a set of small port open chamber heads that i plan on putting it on a 454 and i was going to leave the 2.06 intake valves and put a 1.88 exhaust in it. and a 3-angle valve job. something just for the street. any opions welcome!!
Old 10-11-2005, 07:19 AM
What casting numbers?
Be aware of running too much cr. Older small port heads also have smaller combustion chambers.
In general, a street engine with a mild cam will run good with small port heads. Should be fine and will get better mpg.
Headers will make a bigger improvement but also make a lot of noise.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
Small Block Chevy Top End Rebuild: How Much HP?? purple1967camaro Hotrodding Basics 13 03-28-2004 06:38 AM
Big Block Square Port Heads Farmer Engine 2 03-07-2004 04:53 PM
Big block to small block 69 chevelle SS Engine 2 08-31-2003 12:06 PM
small block, big block crevette Hotrodders' Lounge 3 04-13-2003 08:35 PM
