Small scale military restoration - spray gun advice. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-06-2013, 05:54 AM
Gearheadslife,
Powder coating is out of the question, this is going to be a 1941-1943 factory finish.
One other question to everybody. I've had some paint made up, see the photos below, which is slightly too light when compared to the original samples.
Can I simply add an amount of black to achieve a match and, if so, would a 60cc (60ml) sample bottle be sufficient to darken 500ml of the paint.
Cheers,
Tom.
  #17 (permalink)
Old 03-28-2013, 05:15 PM
I have a problem with my Lafette 42 restoration.
After stripping the paint and washing off the stripper I'm having big problems with corrosion. Now, I've got the Phosphoric Acid to get rid of the rust but the problem arises when I want to wash it off as it is basically water based and if I use water to wash it off then it just flash corrodes again, therefore, I wanted to use a spirit/oil based wash.
I've tried Nitro Cellulose, denutured alcohol but, of course, that is how I found out PA is water based as it does not mix, or rather, wash off.
Any ideas on how to wash off a water based rust killer without coroding the steel?
Tom.
Need Spray Gun Advice!! gxL& Body - Exterior 0 12-08-2010 04:59 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 07:38 AM
Advice on first spray gun Hallsy Body - Exterior 1 05-26-2006 02:38 AM
ADVICE ON PURCHASING A HVLP SPRAY GUN STATUTORY GRAPE Body - Exterior 38 05-27-2004 12:30 PM
