Small Size Alternator
I am having some problems with finding room to mount a alternator on my Anglia,
with the blower drive pullys, narrow frame , coil/overs/mounts Etc.. there just isn't any room to mount a alternator, and have it driven off the crank my next object is to maybe find a SMALL sizes alternator that could possably be mounted some where other than the front of the motor and be driven by a elect. motor like is sometimes used on water pumps, Anyone have any ideas what might work? I have been looking at atlternators off of small yard tractors, but no luck so far,, I am open to any suggestions you guys might come up with Thanks Bill |
There is one alternative you might consider. I've seen street rods with the alternator driven off a pulley on the pinion flange of the rear axle. Naturally it doesn't charge when you're not moving, so keep idling to an absolute minimum.
Another thought is to turn the alternator around so the pulley faces towards the rear of the car and drive it off the inside of the blower belt. This might be a problem for radiator clearance, however. |
And Thanks Joe,, never know how stupid some ideas are untill you open your mouth ,, and insert foot,,, after reading Scooters article,, I went out and mounted the front fenders and Grill shell.. The radiator sets forward enough to get the altenerator in there.. it will have to be on the Pass. side, because of the degree wheel pointer.. Thanks guys... Last edited by Bad Rat; 06-30-2010 at 02:44 PM. |
another dumb question on alternators,, do they all charge regardless of the direction they are rotating? or is it just the cooling condition with reversing them? or is this Power master special built to charge in either direction,,,the reason is ,, the cost on that 8142 Powermaster is right at 500$ ( don't know if that is list or my price)
I have 3 new altenators that I could use if they charge either direction. its worth the dumb question if so,,,,,
This does not answer the question just mentioning it. Have seen an alternator driven off the rear end, it was a race application.
The power master is small and 100 amp http://www.summitracing.com/parts/PWM-8-881/?rtype=10 this one is small only 60 amp http://www.summitracing.com/parts/CTR-77-500/ reverse direction , never though about it, but we are talking AC, the alternator cooling would have to be addressed . to find out take any alternator to the local AZ and have them pop it on the test stand twist the drive belt and see what you get ... Report back I am curious ... Last edited by pepi; 06-30-2010 at 09:11 PM. |
..... nice wheels on the front of that beast ....
after doing a little searching I came up with a small alternator , rated at 55 amps,, not sure that would be sufficient to run water pump, fuel pump, MSD ignition, and charge the batt,, and maybe some lights gonna keep looking some,, You guys think 55 amps would work?? Oh Yeah,,, you were wondering if all alternators will charge in either diration of rotation,, every thing I could find said they will all charge but need to have internal cooling fans,, |
Good Luck.....Love your build! Ken |
Been having problems with posting picturesmm so this is a test,,
![]() seems to work fine,, now I know its the other site I was trying to post on |
| Harmonic balancer size question. Big vs. small | johnbelanger | Engine | 3 | 02-15-2008 11:19 AM |
| Small frame (case) GM alternator donor cars | ken47 | Electrical | 3 | 05-01-2006 10:01 PM |
| CS130 alternator 'size' | cucumber1949 | Electrical | 6 | 12-25-2005 09:17 AM |
| Which size of alternator pulley?? | tornado-tech | Engine | 5 | 08-07-2005 09:56 PM |
| New Powermaster alternator, broken? | arch | Electrical | 2 | 06-12-2004 10:38 PM |
