Small Temporary Air Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 05:31 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
So, my garage wiring stinks.
It's wired into the kitchen circuit, and my normal air compressor (says on the motor it draws 17 amps) pops the breaker.
Not wanting to burn out the motor, or cause any issues (up to and including house fire), I'm in need of a 20amp dedicated circuit for the air compressor, ideally in its own fuse box in the garage. This way the kitchen circuit can be just for the kitchen, and no worries on having to flip breakers.
Long story short, I use an air compressor for general tire inflation, and I run an impact sometimes. My neighbor guy has a really small, quiet (diaphragm pump?) Campbell Hausfeld unit that offers about a half second on the impact before falling flat on its face and taking a few minutes to recover. Something that small is out of the question.
However, if I were to get a 'circuit friendly' compressor, I'd want to be able to at least break a lugnut loose before it runs out of air and needs to kick on again.
I prefer oil lubed units, but am open minded towards the noisy ones too.
My price range is about $100 or less, but if something awesome comes up that costs more, feel free to post it.
Any suggestions?
Thanks
Matt
Old 01-06-2012, 03:29 PM
i have my shop wired up to an extra 220 line i had in my box but you could hook yours up to maybe a central air unit only use the compressor when your house air is off, or have an electrian come in and have it wired to its own box and breaker
Old 01-06-2012, 03:36 PM
nine4gmc's Avatar
Hi Matt,
To be honest, I would invest that $100 in having an electrician add a dedicated outlet. I ran my outlets myself after reading a Home Improvement Electical DIY Guide.
The problem with smaller compressors is obviously less output.
Old 01-06-2012, 06:33 PM
Wiki Edits: 7
Originally Posted by nine4gmc
Hi Matt,
I was sort of thinking this (first part).
As for the second part, that's true for sure!
Do you have a small lightweight compressor? weirdbeard Garage - Tools 10 04-26-2009 06:07 PM
How to get the most out of small compressor? Slickriffs Garage - Tools 3 07-25-2007 07:22 AM
Small Compressor What Gun? pi71 Body - Exterior 6 08-30-2006 03:50 PM
Construct a small temporary paint booth marlaofsealbeach Introduce Yourself 3 08-26-2006 02:50 PM
Is my compressor too small? asennad Body - Exterior 4 07-22-2003 02:52 PM
