smaller fuel pump body needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2007, 10:23 AM
Hello everyone, oes anyone know of a smallblock Chevy fuel pump that is smaller than 4.1 inches,measured from the back of the bolt up flange to the outer edge of the case.Under my 48 Chevy coupe is an S10 frame with the front crossmember modified to fit the Chevy fuel pump on one side of the 350 and the power steering pump on the other.The chassis is basically finished except I have concerns about breaking the fuel pump off when I start the engine because the pump is scraping the frame.The local performance shop wants me to install an electric fuel pump and regulator which is the last resort for me because of cost,noise and the time to plumb all that into the fuel system.The gas tank has an electric fuel pump in it but it has been suggested that if I run that without a return line the pump could burn out at any time.The engine that I am running is a 1985 Chevy 350.
Old 08-28-2007, 12:21 PM
DoubleVision's Avatar
Why not just notch the frame enough to prevent the pump from contacting the frame? If your worried the notch may cause a weak structure issue, you could always add a steel brace to the outside the frame of where the notch is just have the plate welded into place. I doubt lightly notching the frame would hurt it any. This is likely your cheapest resort, a few minutes with a die grinder and carbide cutter would do the trick.
Old 08-28-2007, 12:36 PM
I have the frame notched right out to the springs and if the springs rub against the steel I will have some squeaks to deal with once its ready for a test drive.
Old 08-28-2007, 12:55 PM
I used that same carter pump, 30 minutes, removed it and sold it. Fuel pressure was 9 psi so it had to have a regulator but that didn`t bother me any, but I learned the advertised fuel pressure wasn`t accurate but many others had told me the same thing before I purchased it and they were right so I was prepared. I used 2 isolated rubber mounting points and could still hear it so it had to go. But I certainly agree it`s likely the easiest route.
Where the concern is on the spring rubbing the frame, that`s what rubberized undercoating is for that you can buy in almost any parts store or wal mart.
Old 08-28-2007, 12:59 PM
I just found this, expensive, but is likely the answer to the problem.
http://www.raceglass.com/item.cfm?itemid=42177
Old 08-28-2007, 01:15 PM
Mikeeal's Avatar
^ The FNG ^
Last journal entry: Stabbin it for the first time.
DoubleVision, that new pump you posted is cool! Pricey though!
Hey mikee, the carter one can be had from Summit for about $72, but I found em on fleebay for $50:
http://cgi.ebay.com/ebaymotors/ELECT...QQcmdZViewItem
Old 08-28-2007, 01:17 PM
The motor is basically a stock 350 Chevy 4 bolt mains,aluminum intake and headers.The performance shop pointed out that new style fuel pump but price and the fact that it could probably pump enough gas to start my own gas station put it out of contention for me.
Old 08-28-2007, 01:23 PM
Mikeeal's Avatar
^ The FNG ^
I'm in the same boat mike, cept mine is still an S-10 all around.
The mechanical doesn't want to fit on mine either. What's weird is I used to own an '82 with a 350 as well and it used a mechanical, and fit fine. I'm now wondering if the frame was notched and I just hadn't noticed. I'm either gonna go with a Holley "blue" or "red", or the Carter that's been posted.
Good luck dude, let us know what you come up with.
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
