Smaller mags on newer cars. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2009, 09:59 PM
58lincoln's Avatar
Last journal entry: New (used) 350.
Hi, just curious, what with all the factory Donk's on newer cars, is it even possible to put say 15" wheels on newer cars? - Alex.
Old 02-22-2009, 12:18 AM
327NUT's Avatar
Almost anything is possible....but it would depend on how big the brake rotor/caliper combination was. Also proper wheel offset and back spacing requirement.
Old 02-22-2009, 07:53 AM
All depends on brake clearance and bolt pattern. Most newer cars have metric bolt patterns that do not line up with the more common 4.5", 4.75", or 5" circles. Similarly, most cars today have different wheel offsets than older cars.
Old 02-22-2009, 06:31 PM
handling has been greatly enhanced over the last 25 years, when the corvette came with 16 inch wheels, but i agree that anything past 17s on a hotrod, is more hoopdee...
Old 02-23-2009, 07:51 AM
The handling improvement has less to do with the rim diameter than with the tire aspect ratio. Of course, if you simply put lower profile tires on the same rim diameter, the tire outside diameter gets much smaller. Keeping the tire OD relatively constant and reducing the aspect ratio requires the rim diameter to go up.
Old 02-24-2009, 05:44 PM
each is a product of itself. technology is getting better, handling is improving, and wheels are getting bigger, as a result. they put 15s on nascar cars , so the tires are more predictable, and more room for error...
Old 02-25-2009, 07:32 PM
58lincoln's Avatar
I guess I don't understand what you mean by predictable and more room for error. .
Old 02-26-2009, 02:01 AM
SSedan64's Avatar
The 15" rims on Nascar cars has more to do with using the tall tire diameter as a spring since they run the springs in a coil bind situations much of the time.
Old 02-26-2009, 05:55 PM
i don't follow nascar, so i may have overstepped my boundaries, i know that michelin incorporates a better "feel" for the events as a tire starts to lose adhesion, therefore allowing the driver to respond more diligantly than other tires that have less research and developement in this aspect.
Old 02-26-2009, 06:08 PM
58lincoln's Avatar
Learn something new every day!
Painting a Metallic in pieces Polish Painter Body - Exterior 18 09-11-2010 06:16 AM
Classic Cars, gas, and the end of the world economy. Gladis Off-Topic 13 04-09-2007 04:51 AM
***? Buick cars with Olds engines and vice versa blown69stang Hotrodding Basics 17 03-30-2006 05:30 PM
old toy cars steve t Hotrodders' Lounge 9 07-30-2005 06:39 AM
Most overrated cars! 88Stang_GT Hotrodders' Lounge 52 08-12-2004 08:18 PM
