Smallest steering box ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2008, 10:18 PM
Just starting my first project and first time here-hello. Wondering if the Vega box is the most compact one available ? I have a stock '30 A frame that has been lengthened 15" in front of the cowl to allow for fit of a 440 Chrysler without touching the stock firewall. Problem is that even with an oil filter relocation kit , the Vega box for cross steer I have for mock-up is hitting the adapter and is sitting right where I need to be to keep the geometry with the pitman arm and drag link. I could sink the box into the frame some by trimming the bottom flat of the frame and a bit on top but then the integrity of the frame is compromised and I hate to have to run a gaudy looking gussett under the box. Any suggestions beyond changing the whole setup ? Thanks
Old 10-08-2008, 11:02 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Corvair is probably still the smallest, best looking box for driver's side steering. They are being reproduced as all new items although you can still find good used ones that need to be reversed if they haven't already been. Very easy modification.
See this
And this
And this
And this
And this
Old 10-16-2008, 03:46 PM
RKkustoms's Avatar
we build stock to kustoms
pinto or vega are nice and small and are great to steer
Old 10-16-2008, 05:16 PM
AXEMAN39's Avatar
You might want to check out a Geo tracker box they are very small and available power or manual, I have a spare manual one if you need it.
Old 10-16-2008, 05:57 PM
Tracker? huh, let me seee what happens after tomorrow. I am picking up an old postal Jeep with right hand drive and may see how and if it may work for me. Thanks for the offer- I may be going that route. Tony
Lowering my steering box LiftFlat Suspension - Brakes - Steering 1 07-07-2007 12:49 AM
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 05:16 PM
vega steering box stiff to rotate pcoghlan Suspension - Brakes - Steering 2 05-28-2006 08:20 AM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 08:11 PM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 03:14 AM
