smb 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2006, 12:23 PM
Curtis
Last journal entry: dash of 68 camaro
smb 400
I have a small block 400 that is 30 over with a set 6” rods what would the displacement be.
It has roller rockers-cam –lifters----a set of world sportsman heads 64cc---is there any way you could give an estimate of what kind of horsepower it may have
Old 03-20-2006, 12:39 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Displacement is 406, but not near enough info for a horsepower guess. Need cam specs, comp ratio, ect.
Old 03-20-2006, 12:40 PM
DoubleVision's Avatar
Displacement is 406. Horsepower estimate I can`t give, you didn`t give enough info.
Old 03-20-2006, 12:42 PM
Curtis
thanks but what would a 400 smb 30 over 400 crank with 5.5 rod be. I guess what I am asking does the pin height change the displacement
Old 03-20-2006, 12:44 PM
Still not enough info for HP estimate. The rod length doesn't affect displacement.
Old 03-20-2006, 12:48 PM
Curtis
I will have to go and look at the cam box and see what the spec's are on the cam and ect-- What about the 5.5 rod vs the 6" rod which would be the best
Old 03-20-2006, 12:51 PM
If you do a thread search, there have been several discussions on long/short rod pros and cons.
Old 03-20-2006, 05:14 PM
Curtis
Build up Critique
Critique this build up for me
Smb 400 30 over--Stock 400 crank-6' Eagle rods- SRP Forged Pistons 10-1 CR world sportmans 202 70cc heads ---- crane roller rockers---Crane roller lifters ---comp hi energy roller cam Lift .570/.576 duration 280/286 rpm2500-6500----air gap intake---Holly street avenger 770 ---csr electric water pump ceramic coated headers ---dropping into a 68 Cam.--what kind of HP could it possibly. produce
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 12:28 PM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
