smells like gas after acceleration - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2009, 01:09 AM
1964 Oldsmobile 442's Avatar
I noticed it a little last year, but seams to have gotten worse maybe?
My '64 has the original 330 bored 40 over with stock grind cam, rpm intake and 600 edel carb.
I have a pertronics setup under the dizzy cap and an aftermarket coil for it.
I have a fuel regulator and gauge and fuel is pumping to the carb at 4 1/2 to 5 on the gauge.
plugs aren't fowled they have a slight tint to them.
It just smells after I get off the gas after accelerating.
I am going to get a new timing light tomorrow to see where it is sitting.
I do use the stock dual snorkel( it is a 442 after all)with a modifies extra bottom plate. I think that may hurt my performance and thinking about going with a k&n with the cleaner top that is an open element.
I do have the purple edel springs in the rods and my vacuum at 650-700 idle is 17-18.
Any ideas would be great to get me started in the right direction. I don't want to take my kids on a ride and smell gas and or possibly get sick or get a headache..
Thanks
Old 06-06-2009, 06:32 AM
tnsmith10's Avatar
when will it rain???
are you still running the carbon canister? the thought of the vapor line/hose that runs vack to the tank could be cracked.
another thought is, does the origional fuel pump come with a return line? and are you running a mechanical or electric fuel pump? what im getting at is if the origional fuel pump had a return line and youve altered that, then maybe the smell is coming from an open return line. other than that, maybe a bad fuel cap? gl finding it
Old 06-06-2009, 01:26 PM
Yeah, this car doesn't have a canister or a return line. The smell does come from the carb after hard acceleration. I am thinking of going through the carb and putting needle and jets back to stock with the yellow step up springs.
Its an edel 1406.
If I try to tune it by a vaccum gauge it states I have late timing.. So when I bring up the timing and adjust the carb i get erratic idle and wore at higher RPMS.
would step up springs let to much fuel in? I do have the stronger springs in. Maybe I'll swap those first..
Old 06-07-2009, 10:40 AM
bobjob's Avatar
maybe float set a little too high and it's dumping a small amount of gas somewhere when filling float bowl?? a bad gasket around carb top??
just saying if it is something new,, might be something basic..and you may not have to dig too deep....
Old 06-07-2009, 05:39 PM
I agree, check the float levels.
Raw gas smell indicates a leakage/overflow problem. Id check all your connections, rubber hoses, steel lines, for any loosness or rotting.
Old 06-07-2009, 07:30 PM
I think I got it.. I swapped out the rod and valve and springs. Re-tuned her and took a test drive.. no more surging at cruise and no more smell of gas after hard acceleration...
No idea why I changed springs or rods and valves in the first place..
gas Bob C Off-Topic 10 03-06-2008 08:28 AM
Diesel or Gas trucks? Gas prices ChevyTruckGuy Hotrodders' Lounge 22 07-12-2007 10:09 PM
A little perspective on gas prices Centerline Hotrodders' Lounge 24 05-23-2005 03:50 PM
AV gas Chevy Thunder2 Engine 51 03-21-2004 01:26 PM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 06:22 AM
