smog 350, more power? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-20-2013, 07:53 AM
Why would you want those heads and for little more then a hundread bucks you can have a set of dart shp 180cc aluminum heads with a set of dual springs already installed for hydraulic roller cams? The dart heads flow just as good as any decent 180cc head and would work perfect with your cam. I am running a similar size lunati voodoo roller cam and with my dart shp heads it runs very strong to about 6 grand and has a nice little lope at idle and is very street friendly and I can churp the tires driving down the highway by shifting from 2nd to third gear in my little s10. That's up to you though and the dart heads are usa made and assembled and where excellent quality and as good as any head I have had. I just checked summit and I guess they have went up a little since I got mine and they are around a grand for a set with everything.
  #17 (permalink)
Old 06-20-2013, 09:00 AM
vinniekq2's Avatar
I would buy bare castings,quality valves and solid roller cam with complete kit. I like more power than most people,,,,
With a small solid roller the idle is smoother(generally)has a wider RPM range than any flat tappet or hydraulic roller with similar specs.
  #18 (permalink)
Old 06-20-2013, 05:54 PM
thanks, I didn't know about dart heads seems like a good option.
so for the following all up im looking at about $2500USD delivered (shipping is the killer, Id have to get each head and the cams/lifters sent individually to avoid import taxes)
cam, timing chain and lifters
thrust button
wear plate
push-rods
dart heads
head gaskets
head studs
brass distributor gear
as for timing cover ill probably just get the TIG out and reinforce the stock one.
plus roller rockers, there's already some on the motor, Ill have to check the ratio see if i can reuse them.
seems like a decent price for what im doing.
but then again, I can get a GM vortec crate motor (330hp 380ftlb) for the same price, less maybe like $1k-1.5k if i sell my current complete motor...
and id have it in the car in a day.
damn decisions..
  #19 (permalink)
Old 06-20-2013, 06:08 PM
vinniekq2's Avatar
for less than 6k you can buy a 415 HP/425 torque 350 from a great crate engine dealer,runs on 87 octane
  #20 (permalink)
Old 06-21-2013, 10:19 AM
vinniekq2's Avatar
wrong place to advertise
  #21 (permalink)
Old 06-22-2013, 01:58 AM
unfortunately 6k is above my budget, I still need money for paint.
im thinking it might be an option to just buy a vortec crate motor, and put the cam i previously mentioned into it. because its factory roller cam block, I wouldn't need to change much would I? just cam and valvesprings? assuming the factory vortec heads can handle the 0.502 lift.
  #22 (permalink)
Old 06-22-2013, 07:46 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Depending on the article you read, they will state max lift on Vortecs is around .470-.490". So you will need to machine down the valve guides to achieve more lift (at full lift you will need around .060" clearance between the retainer and seal). The valve guides will also need to be machined to accept a positive type seal. You can buy the tools and do this yourself, or have a shop do it.
Keep in mind that the valve guide boss on a Vortec is .845". Instead of using an inner damper spring, engineers relied on this tight fit to damp any oscillations and spring surge with a tight fit inside the spring. Up until the Vortecs, the boss was .785"...so if you go to a dual valve spring, be sure you verify the inner diameter of the inner spring. If needed, you can have a shop machine the boss diameter down to accept a smaller ID, as well as a larger OD outer spring.
This is a pretty good place to start reading on Vortecs.
http://www.crankshaftcoalition.com/w..._cylinder_head
There is also a section in there about the costs of switching to Vortecs.
  #23 (permalink)
Old 06-22-2013, 08:27 AM
vinniekq2's Avatar
You said time was important and cost of shipping multiple orders,,,
Thats why I said to get the 415 HP crate engine,(comes with shp heads,retro roller and a warranty)
I would seek out a GM roller block if there are any good cores where you are;
look for a 3.62 stroke crank x 4 inch bore
used roller lifters,the shops here have buckets of them for scrap,gotta be a good set somewhere,
rebuild the short block stock,use good pistons rather than rebuilder pistons,
align hone/square/deck the block,
balance,
heads would be either dart shp/edelbrock e-tec or w/e is best bang for the buck
If you think iron heads are better for the Harry Handcuff problem,then dart has a good couple castings(sportsman)
probably use O.E.M. valves or other decent valve,not chinese.
I would use a .480-.500 lift roller cam,duration and lda to be determined after heads are located and CR figured.
not sure how much you will save in cash and Im sure the time would add up fast and soon bother you?
I would still want north of 400 hp
QUESTION: if the engine you build has a lumpy idle and aluminum heads,is that going to be an issue?,reason,
I figure if you use iron heads,a little less CR and a wide displacement angle cam,you can still get 400 hp and almost smooth idle,running on mid grade fuel.
engine will need headers and good exhaust
  #24 (permalink)
Old 06-22-2013, 06:48 PM
techinspector1's Avatar
Wiki Edits: 326
NOW HEAR THIS: MAX LIFT ON STOCK L-31 VORTEC HEADS IS 0.420"
The play that is left over is the safety margin.
  #25 (permalink)
Old 07-31-2013, 06:51 PM
first up let me say I appreciated all the help so far, thanks guys.
ok now so I did a bit more to try and figure out what is going on with this engine.
I got a borescope and inspected a couple of the pistions through the sparkplug hole, the pistons are actually flat tops, and have quite a large valve relief, and there is some sort of pitting or carbon build up ontop of the pistons? is this bad? or because its zoomed in it might look worse than it actually is?
the picture shows the part of the piston top with the cuts for valve clearance.
pic1 that dimple thing is the center of the piston top, and you can just see the cylinder wall top left.
the pictures are **** as its a USB borescope on my laptop, but the video card is crap so it wont capture, hence I had to take a photo of the screen with my phone.
the motor makes 160psi (dry) across all 8 cylinders, and shows evidence of rebuild at some stage (block has been skimmed / machined down till the engine number is barely visible), it runs ok but has a very slight misfire, no smoke or audible detonation.
I guess the best thing to do is pull the heads and inspect it further?
  #26 (permalink)
Old 07-31-2013, 10:06 PM
I'm a ford guy but maybe this can help. On my '95 mustang Gt, I swapped the 5.0L for a 393 stroker. It had 10:1 compression, AFR-185 heads, 226/226 @ .050" cam, and a ported intake. It made 365 RWHP and had no issue passing California emissions. That very motor with 8.25:1and 10 pounds of boost from a vortech S-trim made 560 rwhp and burned cleaner than the factory 5.0L.
Muscleing Up a 350 Vette Smog Engine 345 desoto Hotrodding Basics 6 03-04-2011 06:38 PM
76' 350 Low Comp Smog Motor - ?'s stumprrp Engine 7 02-02-2010 09:30 AM
350 emmision/smog? countryboytn Engine 8 10-19-2009 06:39 PM
smog diagram 78 chevy pu 350 engine harmon Engine 3 08-31-2008 01:47 AM
smog, smog, smog....CA smog , failed. jakeslim Engine 12 08-20-2005 11:59 AM
