smog pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 09:03 AM
smog pump
i have a 305 tbi 91 caprice i want to remove the smog pump can i use a 91 k1500 305 tbi w/o AP w ac belt to remove the smog pump
Old 01-16-2011, 11:07 AM
LATECH's Avatar
I have an old serp belt that I use to measure for things like this. Just cut an old belt string it around the pulleys have your buddy pull the tensioner back about 1/2 to 2/3 of the way, mark the belt and measure it.then count the ribs and order a belt. If you order a gm belt they are now measured in Millimeters so you will have to convert to get the size in inches or get the belt from goodwrench.
For example a 6 rib 93 and a half inch belt would be K060935
If you want a metric belt multiply by 2.54
935 X 2.54 = 2374.9 or 2375 rounded off
Smog pump yea or nay oldred Engine 11 08-27-2007 06:52 PM
Help with a smog (air) pump 78 GMC Obrien78 Engine 5 07-25-2004 12:45 AM
smog pump max RPM?? deuce_454 Engine 16 04-12-2004 10:32 PM
smog pump gone 68_6cyl_camaro Engine 2 04-27-2003 01:37 AM
smog pump RodneyUSAF Engine 1 02-22-2003 09:20 PM
