i have a 91 caprice 5.0 305 im going to be putting headers on real soon and when i do i want to delete the smog pump all together. the smog pump has the aluminum piping that bolts into the block is their a bolt kit for them holes when i remove it.
Befor any one asks i dont live where i need to have a smog pump by law it robs power and it sucks
Why can't you just go to Home Depot and get whatever bolts or plugs you need? What do you need to plug once the exhaust manifolds are gone other than a valve cover grommet?
i did a quick look awhile back and it looked like their in the block their not their on the exhaust manifold which will be going in the garbage but i do have another ?
their is a vacuum line from the smog to the tbi do i just cap it or is their somewhere i can run it to another vacuum
Yep, just cap it with a rubber cap the correct size.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
