smog pump belt not lined up - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2012, 06:13 PM
Theecat-mobile
would anyone have a diagram of the smog pump/brackets/belts for 1977 corvette...350 engine? or info on fixing the belt? its not lined up proper and makes a noise.
Old 09-02-2012, 09:09 PM
RWENUTS's Avatar
Try some of this stuff first. Spray it on while running. It will quiet it down.
Quick Supply of Specialty Adhesives, Chemicals, Coatings, and Lubricants, MALAYSIA: Belt Dressing Spray
Old 09-03-2012, 12:27 AM
Theecat-mobile
1977 corvette smog pump belt
I'd like to line up the belt properly. I don't know where to put spaces to be correct. I was hoping for a diagram or someone who knows how to fix the belt right and pass on the information?!?
Old 09-03-2012, 08:09 AM
RWENUTS's Avatar
You got a pic! Is it like the one in the link. Does it have it's own belt?
Which way is it out of line? Inward? or outward? Or on an angle?
http://www.vetteweb.com/features/vem.../photo_02.html
Old 09-03-2012, 08:35 PM
Theecat-mobile
smog pump belt
this is the situation...I don't know the proper spacer bracket set up so the belt will line up straight.
Old 09-03-2012, 08:54 PM
RWENUTS's Avatar
SEarch with google images. That's how I found the other pic. There's bound to be a diagram somewhere on there.
Google Images
Old 09-04-2012, 09:02 AM
1971BB427's Avatar
It appears to be out the corect distance, but it's cocked at an angle. Try loosening the belt and then all the mounting bolts, and see if you can bring the front up slightly, and then tighten the mounting bolts in that position before setting the belt tension.
smog pump mafiacustomz Engine 3 07-23-2011 10:58 PM
smog pump mafiacustomz Engine 1 01-16-2011 10:07 AM
electric smog pump scholman Electrical 10 12-29-2005 04:56 PM
smog pump gone 68_6cyl_camaro Engine 2 04-27-2003 12:37 AM
smog pump RodneyUSAF Engine 1 02-22-2003 08:20 PM
