my dad has a 283 out of a 67 chevelle in his 67 rs camaro. the engine had a 2 bbl intake and carb and also a smog pump. we switched to an air-gap intake and a 600 cfm carb but the bracket for the smog pump wont fit but we were getting rid of it anyways. the problem is that the pulley on the water pump ran around the crank and adjusted around the smog pump and now there is no belt to run on the water pump. anybody had this problem? is there a new pulley i can get for the water pump that will include crank, power steering, alternator, and water pump? Help please
cant you just use s shorter belt??
problem solved. got a pulley off of an 80's chevy conversion van with a deep enough offset so i can use one belt for everything.
