smoke
hello just finished building a 360 roller ran good on the dyno
but when i dropped it in the car ive got some puffs of smoke coming out of the breather filters what could this be? |
smoke'n
don't forget its still a new motor and will need some miles to seat everything... u using a pcv and breather on the other side of engine ??
what kind of power did it make?curious,,,
all motors have some blow by.If you ran it on the dyno,shes broken in. are you using a positive valvecover vent? |
Do a leak down test at TDC to see if there is an issue with ring seal maybe the block was not prepared correctly?
smoke
no im have breathers with elements on both sides the smoke/steam is consistant but it also puffed a large cloud of smoke a couple times wile idling
smoke
how is a leak test performed?
i had the engine professionally built by a reputable builder but i thought maybe one of the rings wasnt seated properly i will be doing a compression test tonight also the lifters seem to be ticking at low idle maybe too much oil pressure? |
Engine smoke
Most auto engines have a PVC valve mounted in the left valve cover with a vacuum hose from it to the large port on the carburetor. Some run a breather cap on the right side valve cover vented through the air breather base. Some run a breather cap with a filter. Do a search on on this site of crankcase ventilation. Make sure the valve covers have baffles where the breather caps are installed or oil splashes up the bottom on the bottom of the breathers.
smoke
we hit 550 bhp 510 torque
siamese block jesel rockers w2 heads stroked and boared 30 over |
| All times are GMT -6. The time now is 07:58 AM. |
