Smokey focus sometimes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2013, 05:43 PM
2006 ford focus,2.0 four cylinder, auto. My problem is that it smokes when you gas it, it's not blue smoke but white smoke, it almost stalls out when it starts smoking, thought it could be head gasket leaking but no coolant loss or overheating, also no water in oil but there is a little more than normal condensation out of the exhaust. It doesn't do this all the time, but gradually getting worse
Old 03-01-2013, 05:46 PM
bigdog7373's Avatar
Of course it's fast
Any codes?
Clean the maf and throttle body. Is the temperature gauge working?
Old 03-01-2013, 05:55 PM
No codes came up and the temp gage is showing normal temp
Old 03-01-2013, 05:58 PM
bigdog7373's Avatar
Of course it's fast
Try cleaning the maf sensor. Sounds like it's running rich
Old 03-02-2013, 04:40 AM
zmaxmotorsports's Avatar
Have you tried pressure testing the cooling system just to eliminate possible head gasket issue?
Old 03-02-2013, 04:45 AM
No fuel smell conning from exhaust. Going to try replacing EGR and plugs. Drove it around block it smoked really bad and got really sluggish but cleared up when I pulled into driveway
Focus stalling tuneup427 Engine 1 07-09-2008 10:18 PM
a smokey problem... markzepp820 Engine 5 03-03-2007 12:33 AM
Ford Focus SVT okie Introduce Yourself 2 07-30-2004 08:01 AM
Focus, the power johnsongrass1 Engine 17 01-12-2004 12:31 PM
smokey 348 Scuzzy Engine 10 10-07-2002 07:39 AM
