Smoking - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 10:02 AM
DoubleVision's Avatar
Smoking
Not long ago I dropped in my project engine, a 350 vortec chevy. Not many mods to it really, problem is, I let it idle for any amount of time, it`ll never smoke any, if I rev it, it smokes like crazy, and there`s no doubt it`s oil smoke. the engine is fresh, and after break in it seems to have a lot of blow by, way more than it should. I used KB pistons with the rings gapped correctly, recently when I was putting it back together, I got the number 6 and 8 plug wires backwards, but didn`t run it no more than a minute and a half like this, but it seems like this was when the problem began, did I break a ring? the heads were okay, the guides checked okay, I dunno what is the matter with this thing now and I`m about to get seriously annoyed enough to scrap the whole thing, is it rings or guides?
Old 04-17-2006, 12:27 PM
T-bucket23's Avatar
Wiki Edits: 26
I would check to be sure your PCV system is working before you do anything else. If there is no crank case vent going on it will smoke and blowby like a mother. I have seen several time where the vacuum port that the pcv attaches to is plugged. If not a compression test is in order. I dont think I have ever seen crossed wires break a ring or do any hard damage but there is a first time for everything
Old 04-17-2006, 12:29 PM
johnsongrass1's Avatar
Race it, Don't rice it!
You need a leakdown test.
Old 04-17-2006, 02:54 PM
Update, Did a check on number 8, shows alot of oil on the plug, compression test showed this pathetic mullet could only wheeze 120 psi, while most of the rest put out right at 170 to 175. I installed almost everything new in this one. I checked the pcv, it`s good from one end to the other. I checked the valves, there adjusted right and neither is stuck open, 120 compared to 170 shows something isn`t right in that hole. Other thing about this one is, it sounds like a diesel, The cylinder clearence checked out good, it sounds alot like wrist pins to me, while KB did send me locks for the pistons, according to my machinist they could be pressed fit as well which was what I had done. I don`t like KB pistons, but they were the only company I could find that had a 12cc D dish piston. looks like I`m gonna be pulling this one back out, after $3800 what`s another couple of hundred?
Old 04-17-2006, 03:11 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Smoking
Sounds like rings. Let us know what you find out. Good luck.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-17-2006, 04:44 PM
T-bucket23's Avatar
Wiki Edits: 26
You may have broken a ring, they usually dont make much noise though. I would also check to be sure it is the proper piston and they are all the same part #. I have seen sets come with 1 different, for instance you may have 1 30 over and 7 60 overs. the 30 over will be real loose in the hole. Yo would probably hear some serious piston slap which could be your diesel type noise.
Either way you need to open it up.
Old 04-17-2006, 05:19 PM
i had that happen to me everyone thought it was a broke ring but the oil passage were it leaks down through the heads after being pumped through the rocker arms was clogged cleaned it out changed the oil and drove it for a bout a million miles
« chevy heads | Mefi »
new engine is smoking potts Engine 7 04-04-2006 02:27 PM
Montana Jumps on No Smoking bandwagon crazygutgut Hotrodders' Lounge 85 04-15-2005 03:39 PM
Okay I thought I blew a ring in the 305 but it's not smoking today stonedchihuahua Engine 7 08-17-2003 07:22 AM
header wrap - smoking? andybird Engine 5 07-08-2003 03:20 AM
SMOKING 350 RONALD JONES Engine 5 05-03-2003 06:12 AM
