Smoking basics - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2008, 12:55 AM
Smoking basics
I have a '73 Chev 350 engine that only smokes a little upon starting. Accelerating and letting it off produces no visible smoke. The truck sits a lot and is used for short trips mostly. I replaced the plugs with hotter ones. The old plugs were black and somewhat damp. The owner always pumped the carb many times when starting. I found that it started quite well with one or two presses of the pedal. Timing calls for 12 deg btd and it is on the mark. (Automatic tranny). Engine looks to be a replacement so no accurate milage is known.
Any opinions???
Old 08-27-2008, 05:31 AM
dawg's Avatar
NAVY VETERAN
valve seals or guides are bad
Old 08-27-2008, 06:07 AM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
That is what the cause is on the old fords.
Every one I have owned (once they got really high mileage) smokes on startup after sitting for long periods. I just ignored it and kept driving them. Never seemed to get any worse.
Thanks Sprecher48 for VW engine basics wiki article Jon Engine 1 05-05-2008 03:08 PM
welcome new Hotrodding Basics moderator: Henry Highrise Jon Hotrodding Basics 9 02-04-2008 08:04 AM
Montana Jumps on No Smoking bandwagon crazygutgut Hotrodders' Lounge 85 04-15-2005 04:39 PM
header wrap - smoking? andybird Engine 5 07-08-2003 04:20 AM
