smoking going down a long steep hill - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2005, 05:34 PM
dawg's Avatar
NAVY VETERAN
i noticed that my car belching out cloud of white smoke going down a long steep hill.
my foot off the pedal and letting the motor do its thing.
im thinking maybe seals are going.
but PCV was wet as hell even though i got a baffle.
so now im thinking to add a bit of steel wool into the baffle to help .
Old 05-29-2005, 06:04 PM
Jmark's Avatar
Stem seals are most likely shot and the guides are probably worn out too. Looks like head time.
Old 05-29-2005, 08:17 PM
coldknock's Avatar
Are you sure it was white smoke? White smoke is steam from the coolant leaking into the cylinders, oil makes blue smoke.
Larry
Old 05-29-2005, 08:21 PM
docvette's Avatar
Wiki Edits: 12
Smoke
Doc here,
Also ATF either through induction,(bad modulator valve) or dripping on exhaust pipes...
Both will give of a sickly sweet smell...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-30-2005, 06:52 AM
dawg's Avatar
NAVY VETERAN
i still think it might be PCV
the hose was dripping with oil once I got to bottom of the hill I pulled pcv and it was wet with oil.
high vacum coming down hill made it suck through pcv
Long or Short Tube Headers? Ray102386 General Rodding Tech 13 05-12-2011 10:16 AM
H-pipe, How long? 85CHEVY Engine 12 09-25-2003 08:11 PM
T-350 Long vs short shaft change zachscc Transmission - Rearend 2 01-21-2003 02:53 PM
How Long? WOW! Madd Syntst Hotrodders' Lounge 20 08-16-2002 10:13 AM
How long has the project been tore down? Kevin45 Hotrodders' Lounge 6 07-25-2002 11:12 AM
