Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Smoking SB, Information Overload
Old 07-31-2013, 05:33 PM
jokerZ71's Avatar
jokerZ71 jokerZ71 is offline
Wrench Turner
There were no 327's made in the mid 70's. 327 ran from 62 til, I think, the very beginning of 69.Your engine is either older by a few yrs,or,it's not a 327.As far as your question tho,are you sure that cylinder is firing? You could be sucking oil into the cylinder from a bad intake gasket,or,other sources.To accurately pinpoint the problem,you need to try a leakdown test.There are threads on here that desribe the procedure.
