Snap-On Compressor Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2006, 08:40 PM
I've a chance to get a Snap-On compressor for $350, but I can't find the specs anywhere, and the guy whose selling it doesn't seem to know either.
The model # is BRA5140H, and it isn't listed on the Snap-On website. The guy did tell me that it's a 37.3 gal unit though. Do any of you fine folk have any insight on this thing....especially with the CFM specs? I want to run an assortment of air tools, maybe paint, and maybe sandblast.
Thanks
Old 10-11-2006, 01:41 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
snap-on compressor
Krazz, did you ever get your compressor up and running? russ
Old 10-11-2006, 04:25 PM
Waiting on a new pressure switch from Brama. Funny story, I had to remove the motor in order to remove the switch. After I pulled the switch out, I thought I'd drain the pump oil to change it out. Well, the oil drain tube doesn't extend far enough out the front of the tank, so I thought I'd jack up the back end of the compressor just a tad to help the draining oil clear the tank. As I was jacking the end up, the motor (which I had neglected to bolt back on) fell off the front end, breaking the motor switch/terminal pad on the inside. So after a little searching, I found the term. pad for $30. All in all, a small job got bigger.
C.
It's a Snap Wire needed butch27 Electrical 5 09-27-2006 07:53 AM
How to use a Snap On timing light? unioncreek Engine 5 06-02-2006 10:35 AM
It's a Snap wiring -How do you mount the fuse box? Stroker56 Electrical 4 04-09-2006 06:55 PM
snap ring problem antiquebob Transmission - Rearend 7 04-30-2005 04:24 PM
It's a snap wiring harness? joe k Electrical 3 01-16-2003 02:18 PM
