Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Snap Ring Pliers Problem
Old 05-27-2006, 08:27 PM
shad88 shad88 is offline
I ended up using a small dremel cut off to make a small grove in each side of the ring so the little projections on the end of the pliers had a place to bite in and keep from slipping. Got it on there on the second attempt. Thanx for the help.
