Snap Ring Pliers Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2006, 03:34 PM
Im putting a Saginaw 4 speed back together and have run into a problem. I can't get the ring on that holds the front bearing on the main shaft. I worked this thing for over an hour and still can't get it on there. I tried internal and external pliers. Does anyone know a trick to getting this thing on? It's driving me nuts!
Old 05-26-2006, 10:12 PM
You need a proper set of lock ring pliers. If you're using the kind with the little projections on the tip, I feel your pain. I tried them and almost lost my mind, as well as a couple of fingers. One of these should do the trick:
KD 2534
Cal-Van 268-834
Plews 72-951
Craftsman 47386 or 00947386000
Mac P21A
Occasionally you'll have to de-burr the edge of the groove and/or the edge of the ring with a file.
Old 05-27-2006, 07:27 PM
I ended up using a small dremel cut off to make a small grove in each side of the ring so the little projections on the end of the pliers had a place to bite in and keep from slipping. Got it on there on the second attempt. Thanx for the help.
Anti-gravity machine? NXS Hotrodders' Lounge 257 05-28-2006 09:48 PM
piston help, and or ring help blake carstensen Engine 2 12-08-2005 08:25 PM
Puzzling temperature problem on the hemi solved Centerline Engine 2 11-26-2004 03:48 PM
Piston Ring New Concepts brainsboy Engine 2 04-27-2004 03:55 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
