Snap together floor tiles - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2006, 09:58 PM
western star's Avatar
I was thinking of doing my garage floor in the 12x12 snap lock flooring system. Can anyone tell me their experience with the several products on the market. I want to use the solid coin or checker plate pattern so I can take an air hose and blow off the floor. Some of these floors have an open pattern to keep the water off the flooring but I can see a lot of crud building up in there. Any info, price dealers etc would be appreciated.
Old 03-30-2006, 10:43 PM
Race The Truck
Last journal entry: Son's Truck
I took a look at that stuff, but if your going to cut and weld it seem to me it would not last long. The only thing I found that was some what ok was an epoxy floor.
Craig
Old 03-30-2006, 11:11 PM
Epoxy was definetly on my mind. I just wanted to get some feedback on the tiles.
Old 03-30-2006, 11:47 PM
Race The Truck
Yeah, I did a basketball court for an in door play area. I think the tiles were 2.50 3.00 a tile. The only thing I would be woried about would be spilling oil on it because of the oil leaking in to the cracks.
It looks good held up very well after two year still looked nice.
Craig
Old 03-31-2006, 02:08 AM
Kevin45's Avatar
Just one of the guys
Living in Arizona, I don't think you have to worry about the snow so that would be a plus. If all you are going to do is park in there then I would say the tiles would be fine. If you are going to do any type of work that involves dirt, rust, welding, painting, etc. then I would say go with an epoxy coated floor. I am speaking dirt from experience
Kevin
Old 03-31-2006, 07:45 AM
Wiki Edits: 49
Originally Posted by Kevin45
Living in Arizona, I don't think you have to worry about the snow so that would be a plus. Kevin
Hay, careful there fella....... we had 31" a couple weeks ago.
Old 03-31-2006, 09:23 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Tiles work good for areas where you just park a car, or shoot the bull with your buddies. Its not the product for a work area though. Even Epoxy won't hold up to jackstands, dragging stuff over it, repeated impacts, etc. Heck, CONCRETE has a tough time keping up with me.....
It all depends on what you do in your shop, and how often you want to repair it. I've labored over coating the floor for years. I came up with one conclusion. Let the oil stains, scuffs, dust, etc become badges of honor. In no way,shape or form, can my shop be accused of "posing". And the $1,000 I saved, will pay for the valvetrain for the bigblock.
Old 03-31-2006, 01:44 PM
Thanks guys you are helping me greatly. I still work in the shop and I do drag jacks around but no welding in that side. I do use floor jacks but some of these tile manufacturers state up to 16000 lbs of weight per 1 sq ft without a problem. I was leaning towards epoxy with mats under the stands but the jack would be a concern.
Old 04-01-2006, 12:07 PM
roger1's Avatar
Mats are unnecessary for epoxy. Jack Stands or rolling jacks or engine hoists will not hurt it at all.
However, if you DRAG heavy or sharp objects across the floor, it can scratch.
Epoxy is very tough and durable. I used the UCoat-It system but was not entirely pleased with it. My brother did his garage with the epoxy from http://www.griotsgarage.com/catalog....3080&SKU=90011 and he was very happy with that.
I've got pictures of my epoxy floor and my brother's in my gallery:
http://hotrodders.com/gallery/showga...0&ppuser=17782
Old 04-02-2006, 09:39 AM
A friend of mine did his floor last Summer. The floor is so shiny that it looks wet. I don't like that wet look as it's very hard to see if you have water or oil etc on the floor. Can you get this epoxy in a flat or low luster finish.
Old 04-02-2006, 11:01 AM
Rick 5150 69's Avatar
I agree with Beenaway, its easier to just hit it with laundry detergent and a hose and broom, or just a leaf blower, I have no stains, hense the laundry detergent I guess, but my floor is a very smooth surface!
Old 04-02-2006, 11:20 AM
roger1's Avatar
The Valspar (Quikcrete) 2 part epoxy system carried at Lowes is a semi-gloss.
I have seen this used before and it works well. However, the semi-gloss finish is more prone to getting dirty from car tires than the full gloss is.
Old 04-03-2006, 06:13 PM
Ah yes good point the shinier the surface the less marks. Maybe the bare concrete is the best way to go.
Old 04-07-2006, 07:13 AM
roger1's Avatar
Western,
I thought you might be interested what I had to say about the UCoat-it.
Scroll down to my posts on this page:
Be proud of your garage!
Roger
Old 04-08-2006, 07:58 AM
dinger's Avatar
I'm with Jeff and Rick on this one, pretty floors look nice when they're well cared for butwhen you start getting scars it's much more obvious. I have enough problems getting work done without worrying about keeping the floor pretty. It's hard enough finding shop time let alone mopping the shop time. Keep a rag handy for the spills and git r done. Dan
snap ring problem antiquebob Transmission - Rearend 7 04-30-2005 04:24 PM
Got my It's a snap harness 302 Z28 Electrical 25 07-28-2004 11:20 AM
Update on the Snap On murder. A32flathead Hotrodders' Lounge 3 02-28-2004 05:22 PM
Snap On Tools HotRodMan Hotrodders' Lounge 23 10-18-2003 10:02 PM
It's a snap wiring harness? joe k Electrical 3 01-16-2003 02:18 PM
