So do i need a An fitting Wrench kit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2011, 08:07 PM
Mikeymuy's Avatar
So i'am doing my first fuel plumbing job with steel braided lines my question is should i go buy the an wrench kit for 45 bucks from summit i really do not want to ruin the paint on the fittings.. is their any tips how to get by without the wrenchs? thanks
Old 03-22-2011, 08:15 PM
BOBCRMAN@aol.com's Avatar
Not Paint. Anodized aluminum. Been using them for years with no expensive wrenches. Adjustable wrench with duct tape on jaws will do the trick.
Old 03-22-2011, 08:17 PM
ericnova72's Avatar
More for Less Racer
As long as your regular wrenches have a good surface finish on the inner side (mine are Craftsman and Snap-On) and you are not ham fisted you can assemble and tighten them without problems or scratches. You don't absolutely need the AN wrenches unless your tools are in bad shape.
I've been messing with AN fittings for 15 years and don't mave the fancy wrenches.
Old 03-22-2011, 10:24 PM
life is a temporary assignment
I use regular wrenches.... Work's good enough for me.. Take your time, You will be OK..
wrench rod on t v skull Hotrodders' Lounge 1 11-19-2009 03:08 PM
Wrench? Stroke Engine 11 04-22-2008 12:00 AM
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 04:12 PM
wrench jackbh Introduce Yourself 2 04-30-2006 05:45 PM
Smallest wrench ive ever seen!!!!! 53fordguy Hotrodders' Lounge 15 10-01-2004 05:07 PM
